They both are priced identically on currys, both look like they have exact same specs, but cant see what the difference is?
Hi @j0nnye
In very general terms, the higher the number (94) the better the spec. You need to carefully compare specifications below. A very quick scan shows different Remotes, Rich Colour Enhancer, built in Mic on the 94. There may be others. Sometimes (may not be in this case) slightly different stands.
Hey there, the only difference is that the XR-50X94S has a built-in mic
Hi @j0nnye
Also, one of them will be a Sony only exclusive on their online store, I believe it's only the 94S.
