Can anyone tell me what version of Android is included on the Bravia KDL-50W815B Firmware version 3.004?
Hi @portsky
Unfortunately you do not have an Android based TV - the KDL-50W815B is a 2014 model TV of which Sony's Android based TVs came out from 2015 onwards.
You can tell simply - if you press the home button on your remote control, an Android TV looks like this:
Your TV will look much like this:
5.something
You can check that in that info area, bottom right icon.
Thought those were from 2014 and don't have Android at all!?
I can run apps like browser and also install apps from a Sony list of apps - eg AccuWeather etc.
So I assumed it has Android, this is why I was trying to find out the version no.
How can I find outout if it has Android and if so what version?
Hi @portsky
@Kuschelmonschter wrote:Thought those were from 2014 and don't have Android at all!?
my bad...... to early and before coffe.
