- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Wall Mounting KD43 XE8005
I have a generic wall mount, screwed into my wall already, so I'm looking to mount my soon to be delivered Sony Bravia to it. A few things I've google'd suggest it wont be as simple as with my Samsung... What will I need to be able to do this?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @AndyCr15,
if your mount allows adjustment of the TV-mounted side to fit the holes on the back of your TV, I see no reason, why it should be more difficult to mount it to your wall-mount than your old TV.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Okay, thanks. It has two bars that have a variety of wholes that can be any width apart that I need, as long as the TV has a fairly flat back with the four wholes, I should be okay then?
Will the screws come with the TV? Samsung didn't include them and I had to order them online.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello @AndyCr15,
that sounds good to me.
Not as far as I am concerned, yet it is possible, that the screws you used with your previous TV fit on the Sony as well.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Do you happen to know what screws would be needed? (Or where I can look it up?)
Thanks for the help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Okay, thanks for your help.
