Im looking for the adapters to fit into the rear of my tv purchased in 2016.
The adapters are needed to make it flush with the bottom of the tv.
Any stockists here in UK are sold out and apparently they are discontinued but they are available in other countries?
Can anyone help with this please?
Hi laineyw,
The official wall mount for your TV is named SU-WL450.
Amazon shows that it will be back in stock on 27th August.
However, there might be third party solutions as well that will suit your needs.
E.g. Amazon's own solution: https://www.amazon.co.uk/dp/B01KBEOEB0
Hi laineyw,
Oh - you mean the spacers.
You're right, they're not available currently. But there's also an alternative solution from Amazon that should do the trick: https://www.amazon.co.uk/dp/B082V92WP4
Hi Elaine,
Hmm, that's boring...
Slowly I'm running out of ideas.
Maybe you could call our spare parts supplier EET Europarts to see if they have an equivalent part?
+44 (0) 333 241 9271
Good luck
I‘ve also tried them and many other stockists but is like finding a needle in a haystack.
lainey2
