- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
August 2020
August 2020
Wall Brackets
Can the wall bracket for the Frame 55" QLED model fit a Sony KD-55AG9 tv ?
Which model will fit closer to the wall ?
Distance for the Frame 55" TV set is 45.8mm from the wall so I would like to know if I can get the same depth with the 55" AG9.
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2020
August 2020
Hi THEPINKHOUSE-007,
That depends on the bracket - if it is VESA conform and has a hole pinch of 30x30 cm you might be able to use it with the AG9.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2020
August 2020
Please elaborate as I have just cancelled my order for a 55” Frame TV that would have had a 45.8mm depth and would still like to know if, when wall mounting I will achieve a similar depth if I purchase the AG9 model.
