Since the most recent update my TV no longer wakes up when I wake my Nvidia shield. It has worked fine previously for the past 18 months but updated this morning and it now fails to wake 100% of the time.
Hi Gareth,
Please can you let us know the model number of your TV so that we can look into this for you.
Thanks,
Ed
Hi Gareth,
We will check this and let you know what we find as soon as we can. In the meantime, maybe some members will have some suggestions.
Best wishes,
Ed
Hi
Welcome to our community!
Have you made sure to enable the Auto TV On option from settings? You'll find instructions on how to do it on this link.
Regards,
Batee5
Hi Garethrobson,
Have you tried connection with a different HDMI cable or in a different port maybe?
Regards,
Batee5
Hi Garethrobson,
Have you tried to reset your TV to factory settings? Sometimes this helps if it's just a glitch.
You'll find instructions on how to do this here.
Let us know if this solves the issue.
Regards,
Batee5
