When using bravia sync, there is a lag when changing volume. If I use the native controller for my Pioneer VSX-1131 this does not occur. This is most prevailant when I hold the volume button down.
Can anyone test and confirm?
This did not happen with 5.0, so something seems to have happened with the update. Full factory reset has been performed.
Can confirm, happening since Android update.
In my case it's KD-65XD9305 connected via HDMI ARC to Denon X2300.
Hi both
Using a Sony STR-DH720 AV Receiver connected to KD-55XD8577 via HDMI-ARC. Watching Freeview - if there is any lag/delay for me, its barely detectable.... So for me, its fine.
@Quinnicus wrote:Hi both
Seems then it is to do with non sony products?
Its a possibility - but would need others to confirm/deny to be sure.
Can I assume factory reset was done after the update?
@Quinnicus wrote:
@Risc0n wrote:Seems then it is to do with non sony products?
Yeah is was in the first post
Just linking the following:
https://www.avforums.com/threads/sony-kd-x850-c-owners-thread.1963228/page-102#post-24772718
I have same problem with 55X8505C and connected ZR5 speakers.
AND Lip sync issues - it seems that sound is 0,1s delayed when using ZR5's instead of TV speaker.
Issue added to bugs and issues list:
https://community.sony.co.uk/t5/android-tv/android-tv-bugs-and-issues/m-p/2299361#M16801
@Quinnicus wrote:Issue added to bugs and issues list:
Thanks mate, also confirmed by our US friends
