Is it possible to upgrade your remote. Ie my 2015 w809 remore has no voice input. But can one buy a newer version?
This should work:-
https://www.sony.co.uk/electronics/televisions-remotes-selectors-cameras/rmf-tx100e
this one indeed will work but it's not worth buying just for voice commands since it's very unpractical for everything else.
Just to add that the Video and TV SideView app also has a voice input option.... But.... I find it hit and miss.
Yeah. Was having a look at that. Must check out the voice search on sideview app
