- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Virgin 360 stb
Just purchased Sony X-ray 55inch oled tv, does anyone know if the remote control will operate a virgin 360 stb?
thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sadly, the model number seems incorrect. However, most Sony Bravia TVs feature support for Bravia Sync which allows you to control external devices that are connected via HDMI.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
For Some Reason Sony Have not updated there firmware to recognise Virgin 360 Remote or Update. But there is a work around.
With your Sony remote go to Settings > Channels & inputs > External inputs > TV box setup > Setup by model number (try DCX960) > TV box > Set up > select the HDMI input that your 360 is plugged into > type in Ziggo > type in Mediabox (or Mediabox Next)
If your menus are different then try
Settings > Watching TV > External Inputs > TV Box Setup > Setup By Model Number > Setup > Select your HDMI that your 360 is plugged into >type in Ziggo > select Ziggo and press OK > type in DCX960 and press Enter > select DCX960 and press OK.
Then Goto your Settings External Inputs, Manage Inputs >HDMI - Ziggo > Custom Name and Rename to Virgin TV 360
