Soon after I bought my TV (KDL-55W808C) I registered in Video & TV SideView which I used with pleasure. Then my motherboard on TV went broken and after a successful repair I can't use the app anymore. It just can't find my TV on my home network.
I check all the settings but still no luck.
Any idea?
You probably need to reregister, as the TV may have a new identity now,
if if this is not it, though, try a Factory Reset,
(Something I normally hate to advise, as it is the technological equivalent of ECT shock therapy, but it is often the thing that works, and the only thing that works, with these Sony Android TVs)
