I am looking to replace existing Sony set (kd49xg9005) with with a KD48A9 OLED but wanted to know if I can repurpose my wall mount without having to move it.
I know the vesa spec is 30 x. 30 and weight shouldn't be a problem, but I am trying to find out how far from the bottom of the tv housing the bottom vesa hole is in cm/mm (and maybe how far from the top tv to the top hole) and also how tall the deep section of housing on the rear is.
Unfortunately no local store has one for me to measure so If anyone has the info, that would be great.
Thanks
You should have all the information in the attachment
Hey MattHP, both TVs work on the SU-WL450, check the Manuals:
