Hi All,
I have just bought a kd55xh81.
I am seeing these flickering dotted lines when viewing any input (They are in the whole screen but only prevalent on dark areas):
They can be seen on Digital Aerial, Apps and HDMI. Only when watching something. Never seen on any menus.
I have tried fiddling with every setting. Hard and soft resets. Factory data reset.
I can't find anything similar anywhere in the web. Has anyone seen this before?
I will get a replacement if I have to but would like to avoid that if I can.
Thanks
Harry
I would say that's a technical issue and recommend to return the TV to your dealer.
