Hi nickmaddison,
Could you try clearing the cached data by pressing on Home, Settings, Storage and reset, Clear cached data?
Cheers,
The_Black_Rose
Hi Nick,
I'll see if I can get some advice for you. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Hi nickmaddison,
That seems a bit unusual. have you tried performing a soft reset as explained here: http://bit.ly/2XmFL2A ?
Cheers,
The_Black_Rose
thankyou that seems to have cleared the fault
