Hi, I have some another problem with USB or disk. I am using my USB/disk on my TV and when I finished I dont have any shortcut for safe removal . Does anybody know how to do that? Thnx
I think that there's an optin for that somewere under "storage" in the main settings.
But, you can just unplug the drive. Don't do that in times when you use some app that are using disk for writing (while KODI is scanning or something like that) but if you use it just as media source than you can unplug it anytime. Safely removing the drive will not help with 36528 USB issues anyway 😞
Hi there,
Can you let me know the full model number of your TV?
Best wishes,
Sean Mc
model number of TV is KD-55XE8505
Hi there,
model of tv is KD-55XE8505 ,
tnx
