As the ethernet port on sony TV only do upto 100 mbps if I was to put a USB 3.0 gigabit ETHERNET ADAPTER into sony x94j usb 3 port and used a tp link gigabit ethernet adapter would it work.????
@AlexKid wrote:Hi,
you are right. For the newest Bravia 9 Series we need a newer USB3 Ethernet Adapter. I searched a while and ordered this one:
I tested it for one week now without any problems
Out of curiosity, I bought the same UGREEN adaptor to try on my XR-55A95K. It didn't work, so naturally I got a full refund from Amazon and returned to my reliable UE300.
Finally got the Android 10 update for my 2020 model XH8096 today (very surprised by that lol).
Had a TP link UE306 lying around. Didn't work with the developer setting and although I tried every USB port.
Just ordered the UE300 and will let you know if that works.
Yup - works with the UE300. Crazy 🤣 I guess the chipset might be supported - but not the other one.
Thanks everyone for the tips! Got proper 900/900 now.
Good Evening
I have a Sony KD-48A9, do you know which adapter I would need?
I never realised the LAN port restricted ethernet to 100. This might be why i get buffering every now and again.
I always thought wired was meant to be better than wifi.
Thanks
Changed internet provider and now TV reaches 500mbps👍
Hi I use tp-link USB - 3.0 to ethernet adapter. It works with my Sony X94J.
