I have a sony KDL 43W807C, can I set it up to do all software updates automatically?
Many thanks Jules
Hi there
Yes you can, but you have to ensure two settings are enabled.
1. Firmware updates:
Home > Help > System Software update > Automatic software download > ON
2. Apps:
Home > Google Play Store > Settings > Auto-update apps > Auto-update apps at any time
