Hello
We got a KDL-55W755C.
It is very slow when we try to interact with it.
I also tries to update a app, tv4 play, but Google play said the Android was to old.
Is there any way to installed a later OS?
Best regards Fredrik
Or a Roku Express or Stick, whose UI I find cleaner than those, plugged into an HDMI port.
No matter how old the TV, it is then limited only by the resolution and brightness of the screen, and, if you have a soundbar or AV setup, if the TV has only ARC, not eARC.
