Anyone know how I unpair/remove the dual shock controller from pairing with my Sony TV everytime it connects? I want to use it with my Shield TV, but it always conflicts.
Many thanks
Hi there
I had the same issue when trying to use PS4. I cant fully remember how, but look at the bluetooth settings info.
All else fails, disable bluetooth
Hi there
Never thought of disabling bluetooth.
There really should be an option to unpair controller.
Thanks
