- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
Unfortunately, I am not able to update the firmware on my SONY Bravia KDL-55W805C
Current firmware: PKG2.257.0010EUA
I downloaded the latest firmware (v3.865 Sony Website) and put onto a USB:
- The update started and a white Led light started blinking on the front panel of the TV
- When the update finished, I went to Home - Settings - Help and the firmware was not updated (PKG2.257.0010EUA)
I tried inserting prepared USB into USB port 1, 2 and 3 and also created two copies of the update on, one of them renamed as 'upgrade_uploader.pkg' having no luck (PKG2.257.0010EUA).
When going to Home - Settings - Help - System software update - Check for a system software update - Update Now:
Please, does anyone know why this is occurring and how to fix it.
Thanks
Tony
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm having the same problem, my firmware just wont update. Any suggestions would be greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I just finally gave up and run this TV from an auxilary device. (Roku). My issue was that the TV was the U.S. model. Seems there is a difference in regional models and that firmware. I was attempting to find older versions to slowly patch my way to a current level (Or something that would update and work from a previous version). I could never get the firmware to finish after 99%. It would reboot and then be back at their previous firmware revision.
NOTE: I never really tried to call a Sony Support to get answers but rather I only tried researching and getting no good solution. So my TV is still at the first firmware revision.
-Best of Luck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
У меня вообще ты застрял не логотипе сони. Обновление доходит до половины и начинается заново. Кнопки не реагируют
- « Previous
- 1
- 2
- Next »
