Connect ITB to USB REC port. I can see it in Storage and could format it from there but I want to record programmes on it (some say disable YouView app first - I have tried both). There is no option to register the drive for recording. Any ideas?
You need to make sure that the HDD device is compatible with your TV for recording. Take a look on this link it might help you to fix this issue: https://bit.ly/3rqnK2L.
Thank you. I have followed all those steps (it is compatible) and the ones in the troubleshooting guide. Issue persists.
What is the current software version? It also seems that the model number is incorrect, are you sure from this model ?
