New blu ray player keeps turning itself off while im trying to watch. Only had it a few days. Anyone have any ideas how to fix this please. Thanks
Hello @Cheekymeeky,
is the player connected directly to the TV or to a receiver?
If so, do you have any HDMI-control on trough which the player may receive a signal to "switch off"?
I personally would deactivate HDMI-control both on the TV/receiver if any is on.
- Nic
Thanks a lot. Done what you suggested and it seems to be playing ok. Thanks again
Hello @Cheekymeeky,
lets hope it stays that way.
- Nic
