Hello all,
I have a Sony tv in my sitting room and another in the kid’s playroom. The remotes are interchangeable, but that means that they work on both TVs - at the same time.
If the kids change channel, or input, it will change on the sitting room tv as well.
How do I reprogram the remotes to only work on a single tv?
Many thanks in advance.
What you're describing would only happen if the remote is connected via Bluetooth, so I assume you have one/two of the Android models.
You can just disconnect one of them and use it Infrared (IR) mode and that should solve it for you.
- JD
