- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Tv
Hey there I was wondering with the Sony BRAVIA KD55XH9005BU 55" Full Array LED 4K HDR Android TV would a normal hdmi lead connected to the hdmi 2.1 port give me the best picture still or would there be a recommended hdmi lead to give me the best picture and does a wall mount bracket come with the tv.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
A high speed HDMI cable should be fine for most purposes, but whether you would benefit from anything faster depends on the device on the other end of the HDMI lead, not on the TV.
See here:-
https://www.lifewire.com/hdmi-cables-and-connectors-what-you-need-to-know-4685377
So what are you planning to put on the other end?
As regards wall mount brackets, these can vary depending on the way the wall you want to hang the TV on has been constructed. So no, you won’t get one with the TV, and this will be an extra cost purchase. As will be the mounting, if you are prudent, and leave it to the experts.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for getting back to me , it will be for my PS4 so what would be ur recommendation and for the bracket I would just want it to be able to tilt.
i did find this one
https://www.argos.co.uk/product/8917724
however is there a product that will be better than that?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
For a PS4, a high speed cable is fine. A PS5, though, will need one of the faster ones, so if you have any ambitions in that direction, you might want to get the faster one for future-proofing.
I can’t comment on wall brackets; I know a man who can, but he doesn’t work for free. OTOH, if he puts up a TV and it falls off the wall, he buys you a new one.
Look at this, though, for guidance:-
https://www.bracketfinder.co.uk/wall-mounts/tv-wall-mounts/?menu=mfilter
