⁰When bluetooth phones are connected, TV volume cannot be turned off. Neither handset nor mute work. HELP.
Usually you should have two volume options in the action menu (options) - one for TV speakers and one for the headphones.
I feel sure you have a reason but why would anyone sit in front of a TV and want volume from a phone?
Please enlighten, may help with solution.
It was you who said you use Bluetooth phones??? Original post.
Hi Peter, I appreciate your reply. I have attempted your suggestion but was unsuccessful. After trying everything I finally gained success, I binned the earphones. Now I am a 'happy bunny'.
Cheers,
Locky.
