When I turns off my KDL-50W755C, it very often turns it self on again.
Sometimes I have to turn off the TV 3 or 4 times before it keeps turned off.
It is connected to WiFi and a NAS and SideView.
Does anyone know how to fix this problem?
first question, have you updated at the latest firmware?
Manolo
Hi there
Im wondering if a device is waking up the TV - without an add-on or separate app Android TVs do not support WOL (Wake on LAN) as far as I am aware. However SideView can wake the TV up using a function called "Remote Start"
Try turning this off in the TVs settings:
Marino - Yes I have the newest firmware.
Quinnicus - I will try your solution and get back to you
