i have a sony tv KD-65AG8.
I am interested in whether a Sony Dualshock 4 v2 Controller is compatible with the TV, mates and can play games downloaded on the TV with it.
I want to buy one, is it ok ???
thank you in advance
We will check this and update you when we know more.
Until then, our community members may be able to offer some information too.
Best wishes,
Ed
Hi Catacam66,
It isn't compatible unfortunately. I found this link on the Sony website: https://www.sony.co.uk/electronics/support/televisions-projectors/articles/00179311 and this is for an older update.
Cheers,
The_Black_Rose
thanks for answer.
but a game controller that will work (compatible) with games downloaded on this TV ???, you can recommend me.
Hi there,
There's a list of the supported controllers on the Sony website: https://www.sony.co.uk/electronics/support/televisions-projectors/articles/00119200
Win_88
isn't it really pathetic that just because they will end PS now service they decided to block DS4 also. So typical....
Does some there really think that one will go and buy playstation just to use their controller? How is it better to tell people to go and buy logitech than their own product. How did Japan even became economic force with that kind of management????
