Strange one really.
I have my TV connected to internet via ethernet cable ,just recently I could not access YouTube or any Google apps ,they say no network connection.
Yet Netflix ,prime video etc all.play connect no problems.So I disconnected cable and tried wifi,this time it says WiFi connected no internet,yet again Netflix etc play fine it's just the google apps and the TV that say no connection.I have checked all leads and connections reboot things etc even removed networks and started again but still the same ,
My TV is x9005 Android 8, build 8.0 OPR2 170623.027.s32 665551
Kernel version 3.10.79
I am having the same issue since a week. I have to hook apple tv which was connected to another tv.
It displays Connected, no internet. The only app which works is NETFLIX. Other than that none of the apps are working.
This should be addressed as not able to watch anything as apple tv is only for short period of time.
Check the date and time are set correctly on the TV.
if the problem is not solved, I think it will be easier to buy Android STB (for exemple https://www.infomir.us/products/mag425a.html )and watch YouTube on the big screen again
