My 55" XF9005 has started switching itself off, then rebooting to the animated Android screen.
Does this have anything to do with the recent update?
Yes in fact, it's started since I installed the recent update.
Try clearing the cached data (under Device Preferences - Storage - Internal Shared Storage - Cached data) then restart by holding power.
Thank you.
I have done this and will monitor the situation.
You're very welcome!
Do let us know if the issue returns so we can help ^^
- JD
Hello!
The issue has returned.
Hi Blumine,
Did you try to clear cashed data again? if this didn't work out, I'd suggest performing full factory reset.
Bat_Rick
