Hi I have a Sony TV KD-55XG8796
I have only had it a couple of months.
The TV is usually on standby and when I go to put it on nothing happens, the TV received the signal but no screen comes on. I am having to switch off from power and then re power up, the screen then comes on.
Any ideas?
@sarbsingh wrote:Hi I have a Sony TV KD-55XG8796
Any ideas?
Hi @sarbsingh
As it is only a couple of months old, you need to go back to the Retailer.
If you want to try something, then try a Reset (probably needs a Factory Reset). This often solves these strange glitches.
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55xg8796/artic...
Hi
thanks for the info, I will try the reset 👍
