- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi I have a AF8 and I keep getting a panel to refresh the tv panel most nights since the new update is this a fault with the tv update
Can anyone help
Thanks
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
We have. We left it for 6 hours overnight and another 3 this morning. And it still came back up this afternoon.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How many working hour your panel have? Did you ever accepted to refresh it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi I had this TV since Nov 2018 and it the first time this as happen.What I did was to select fresh now and turned the TV off,next morning the TV was working ok then last night it happen again So can u tell me the correct way of refreshing my TV please
Thank's for your help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Did you turn off the TV or the TV turned off by itself? Have you got any message stating that it was the procedure finished right? It takes if I remember well about an hour.
The procedure is suggested by the tv aprox every 2000 hours of usage.
You may try another time to confirm it and leave the tv working without touching it. In case it does not solve, contact the support and do not try anymore because refreshing too many times the panel can lead to wearing it too fast
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Not sure but had TV since Nov 18 and this the first time it's been doing and we r pensioner so it's on alot per day
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Turn TV off with the TV remote and no message to say its I have done a refresh again and the TV turned it self off so I am leaving it off until 1200 that will b 1.30 hrs the TV will b off
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you want you may check the usage by following this procedure:
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume down + Power
It will show 3 number of which the first one should be the panel usage hours count
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi I have now sorted it hopefully this time I selected refresh now let the TV shut down it self left the TV off for 1.15hr to make sure turn TV back on with the TV remote and up came a message your tv as been refresh successful I am just hoping tonight it does not come back on asking me to refresh
Thank for your help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you are welcome!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi It had 2003hrs and after looking it refresh ok so thanks for your help
