I've just bought a kd55xh95 TV it disconnect the TV speakers when headphone jack or Bluetooth us used. This is annoying as I'm hard of hearing but my wife isn't.
Anyway around this problem.
Thanks
Chris
Get an Optical to Bluetooth transmitter off Amazon, which you should be able to for around £30 or less.
Then you can listen on that, as Optical Out is always on, and independent of the TV volume and speakers which your wife can listen on.
