TV doesnt play in 4k
YoItsNikon
Nowicjusz
I own a KD-55XF8096, and it is only playing in 1080i. I have Disney+, Netflix etc., and every movie is in 1080i, even tho they are supposed to be 4KUHD. I've tried picture settings, but I cannot change the resolution, only HDR.
Any ideas what can be the problem? We have high speed 8k router, latest firmware etc.
Appreciate the help in advance!
2 ODPOW. 2
profile.country.GB.title
royabrown2
Zawodowiec
@YoItsNikon
How do you know it is only 1080i?
Do you have 4K subscriptions to Disney and Netflix, and are you sure you are selecting 4K versions of things?
Do you have anything plugged into your TV, apart from the mains, and maybe an aerial, satellite cable, and/or an Ethernet cable? If so, remove them (HDMI cables/devices, USB cables/devices, Optical cables/devices? If so, remove all these and try again.
If you now get 4K, put those devices back one by one until you lose 4K again, and you will have found the culprit.
If still no 4K, open the BBC iPlayer, and select a 4K programme, His Dark Materials maybe. Does that play in 4K?
If still no go, Factory Reset the TV, and try the above again,
Please report back how you get on!
NB: What is an 8K router?
profile.country.US.title
dajsam
Nowicjusz
do you have the HDMI setting format to Enhance?
• HDMI IN 2/3
To enjoy high quality 4K 50p/60p
contents, connect a Premium High Speed
HDMI cable to the HDMI IN 2/3 and set the
[HDMI signal format] to [Enhanced
format].
For details of supported formats, refer to
