Hi…..since the last big update my tv does not switch on immediately.Every so often it goes into reboot mode and I get the “Sony” symbol followed by the “bouncing balls”and finally the Android symbol.This does not happen every time and it is only happening since the new update.Is this a common problem and does anybody know if Sony are going to address the problem.
Thank you
Den
What TV model do you have and have you tried double-checking that you have the latest software? This used to be an issue with some older TVs/software versions but was fixed.
