Can someone please explain why I have to go through YouView for ITV and Channel 4 apps? I do not have an aerial attached as I used to have Virgin Media but have sent all the equipment back and now only interested in catch-up TV, so I cannot use YouView to tune in as I have seen elsewhere on here. Why can't they be downloaded from Play Store? Tried looking there and they are not available! This is ridiculous!! 😞
Sony control what you can get on play store. Get the Itv hub and 4more apps and upload to TV by USB.
I am reminded yet again why I love the One Connect box on my Samsung TV; it will be a hard choice next year between another of them and an LG OLED.
2020 Sony sets finally let you have the itv Hub and All4 without having to have YouView, but no-one will tell me if you still have to tune the sets with a terrestrial aerial to get them.
Your best bet then, is to get behind the TV one last time, and install a Roku Stick; this will augment its smarts not just with those two players and no need for an aerial, but with NowTV, if it is not yet on the set itself, Amazon Video, and all manner of other apps.
Hi Steve,
You should be able to update YouView via Google PlayStore.
However, you need to be signed-in with your Google account to do so.
Sorry, please explain. Thank you.
xxx
We have to be elliptical here:-
https://github.com/hoshsadiq/bravia-youview-player-launchers
Nuff said?
Though you do still need to have tuned in the channels, maybe with a room aerial. But you don’t have to leave it connected after that initial tuning.
I really appreciate your help and thank you so much for the link. However, I do not have an aerial and my TV is fixed to the wall so I would need to do a lot of faffing about to try this! It would be much simpler if Sony gave us access to the apps! Channel 5 and BBC are accessible, so why not the others? It's just ridiculous! But thanks again for your help. Cheers 🙂
Anyone with a 2015 TV get the now tv app, I see it is on the 2018 model but not on earlier models which Sony have not updated as yet.
