My TV has e search mode used by pressing a microphone on the remote and speaking which is great and very useful but it can activate without me touching it and it gives me random searches which interrupts my viewing anyone else have this problem and how is it fixed
Your tv has also an integrated microphone so you can send command without touching the remote. It is a feature not a problem. And can be de-activated
Someone used to say "user manual is your best friend"
I know all about the google play button and it is turned off on my TV the problem is the feature where you push the mic button on the remote to search .It goes off by itself if there is loud noise on the TV so in the middle of a program the search for you tube comes up without me pressing the button to use the mic
how is the mic button on the remote deactivated it is not the google mic that is the the problem
Probably I didn't understand what your problem is... I just advised (but you say you already know it) that your TV has a built in microphone on the TV itself that doesn't need the remote button to be activated. If that is already off your problem may be different
Wiggle the button on the remote. Make sure it’s not stuck down with something like biscuit crumbs or gorilla snot.
The "Button" on the remote is not a button it's the remote's microphone.
Disable it in settings.
checked no snot
