Need some advice.
I have a sony ag8 oled tv. I see from the settings that you connect a subwoofer into the headphone port of the tv. Therefore, can anyone recommend a subwoofer to connect to the tv?
I used to have a Quake by Rel on my old system....used to rattle the windows 😄
Hi, I have the same TV. Have you found a subwoofer that works with this model yet?
I would appreciate knowing anything you've found out.
No, but I did make enquiries with richersounds and they recommended this one:
https://www.richersounds.com/tv-home-cinema/subwoofers/cambridge-sx120-sub-blk.html
