I have just bought a Sony Bravia KDL-32we613 to replace an older Sony Bravia which unfortunately wont support iplayer anymore. Now I find, on the new one, I have to switch subtitles on for every programme rather than having them on permanently, and this is so annoying. Does anyone know if theres a way I can keep them on? When I go into Options, subtitles is says they are off but I can find no way of changing that. Ive been having a 'Grrrr' afternoon!
If you can help, a big thankyou.
Hi @tolemancat, welcome to the community.
Are you using a digital text application? The manual for your TV says:
Mick
No, change channels and the subtitles disappear. Needs fixing in next software upgrade.
