Currys advertise the
KD43XH9196BU
as having 4 speakers. I can only see two at the bottom.
help please
Ah, an obscure thumbnail bruiting the the Acoustic Multi-Audio feature this TV doesn’t have.
Much like the 9-ness it doesn’t have either, as Sony have inexplicably let Curry’s have a model number in the 9 range for a TV that is only in the 8 range.
This would exercise me rather more than a thumbnail that contradicts the spec; but the spec is correct, and this set doesn’t have Acoustic Multi-Audio. Or they would put that in the spec, I would have thought.
There’s a long wait to query this with Curry’s by phone, and no email, only a postal address. But I might have a bypass for you; on this page:-
https://www.currys.co.uk/gbuk/contact-us-1181-theme.html
click that Need Help button, and you will get a ‘bot. Ask your question three times, ignoring the first two responses, and you will be offered the chance to continue the chat with an agent (hopefully liveware) and you can discuss this with said agent, if the wait is not too long.
Hi @Gerry1952 I have just had a quick look at the Curry’s website and it clearly says Speakers 2.
AUDIOSpeakersAudio powerSound enhancement
2 |
20 W |
- Dolby Atmos - Dolby Audio - DTS |
Maybe they‘ve corrected it since you last looked?
Look at the small photos under the main photo
