Hvilken soundbar anbefaledes til denne? Og hvor placeres den hen?
Mange tak
Hi Bobby,
You have been automatically redirected to the UK Community, since Denmark does not have a separate Community. Therefore, could you please write your post in the English language? More people will be able to understand it that way.
You can also contact the Danish Support team for assistance. You'll find a contact form and phone number here.
Best wishes,
Arthur
Hi Bobby379,
the recommended soundbar is the HT-XF9000.
https://www.sony.dk/electronics/sound-bars/ht-xf9000
However, it will be difficult to mount to your solution.
I know that @IamNic has printed some parts to attach a soundbar to the TV in the past but I'm not sure if this would fit your TV as well. So maybe a different solution would be needed (e.g. some metal brackets that are mounted to the stand you're using).
