Hi there,for dimensional reasons I bought a Samsung Soundbar (HW-N450),and while it works with HD channels and Bluetooth for music with my iPhone 6 there is no sound from the SD channels.
I have the HDMI cable in the ARC port so I’m stumped 🤔
Anyone know what I’ve done wrong ?
Thanks in advance.
Hello @Pigmalism,
sorry for the misunderstanding - that was not what I meant.
I was referring to the audio format e.g. "Dolby Audio" or "Stereo" or "DTS" or "Dolby Atmos".
- Nic
Hello @Pigmalism,
did you check your TVs audio-output options? Maybe the audio format of the SD channels is different to that of the HD channels?
- Nic
It’s set to Audio System
Hello @Pigmalism,
- Nic
Ha ! ,Nic I just did a factory reset and all is well 🙄😆
Thanks for taking the time to answer my query mate 👍
FWIW it’s Dolby Digital Plus 😋😄
