Hi
I have a Sony KD55XD9305BU Smart Android TV which is linked to a Cambridge TVB2 sound bar - both a few days old. Linked via the HDMI 4 port which is ARC.
My Virgin Media box, a TV Media Box, and a Bluray player are also connected to the TV via HDMI.
The sound bar works faultlessly with the three boxes listed above.
However, when I use the TV's on board Apps, such as Amazon and BBC I player, the sound fails to make it to the sound bar and I either get silence or a loud clicking. The picture will also stall when trying to watch apps with the sound bar selected and switched on. If I switch to TV speakers then the apps work fine.
I can't really take the sound bar back as I would have to admit it works fine. Is my TV maybe malfunctioning or is there some setting buried deep in the menus that I haven't found yet? Spent most of Xmas on this so any help much appreciated.
@rooobb wrote:@preeder1963 it was not me but @royabrown who suggested to check the connection but still happy you found out the way
Thank you @rooobb - have a kudo.
But like you, I am happy to see a satisfied user with things all patched up (literally in this case :smileylaugh:) so they can enjoy their TV!
@preeder1963 - Glad its working again. Fingers crossed it sticks this time (pardon the pun)
