Hi all,
I’m running into a recurring HDMI/eARC issue that started after updating my Sony XR-55A80L to firmware version v6.8022. Hoping others can confirm or suggest a solution.
TV: Sony XR-55A80L (2023 OLED)
Amp: Sony TA-AN1000 (eARC capable)
Source devices: NVIDIA Shield Pro (fast boot), PS5
Connection: HDMI with eARC enabled
Bravia Sync: Enabled
Amp setting: Network Standby = ON, HDMI Standby Through = ON
TV Audio Output: Set to “Audio System”
eARC Mode: Auto
After the latest firmware update (v6.8022), I’ve been intermittently getting this message on boot:
“TV speakers active due to communication failure between the TV and audio system.”
The message appears at startup, particularly when using the Shield, which boots very quickly.
However, audio still routes to the amp correctly after a second or two.
The PS5 doesn’t trigger the issue, likely because it takes longer to boot and gives the amp time to complete the eARC handshake.
Double-checked Bravia Sync and eARC settings on both TV and amp
Ensured HDMI cables are high quality and fully eARC-capable
Amp and TV both have latest firmware
Network Standby and HDMI Standby Through are ON on the TA-AN1000
No HDMI splitters or ARC extenders in use
TV now starts up faster after the update — may be outpacing the amp’s readiness
It seems like the TV is trying to establish an eARC connection before the amp is fully ready, especially when the Shield boots quickly. This results in a temporary fallback to TV speakers before switching back to the amp. Since the PS5 takes longer to boot, it avoids the issue.
Is anyone else with an A80L or TA-AN1000 seeing the same issue after the v6.8022 update?
Could this be a firmware bug, or just a timing conflict due to faster TV startup?
Are there any recommended tweaks or CEC strategies that solved this for you?
Could this affect the TV or amp long-term, even if audio functions normally afterward?
Appreciate any advice or feedback!
Thanks in advance.
Hi everyone,
According to the Sony UK support site, a new update has been released for the XR-55A80L. I’m at work right now, but I’ll try updating my TV later today.
**Just wanted to share the news—**if anyone manages to update earlier and notices that it fixes any error issues, I’d really appreciate a quick post about your experience!
Thanks!
Unfortunately the updates didn’t solve the problem for me.
this morning I got a message saying there’s a new update for my TV. I’ll update later and report back. Fingers crossed that it finally fixes the issue.
Any update on this? It's been ongoing for so long now, with no resolution. Are Sony still working on this?
Last Wednesday, I received an email asking if the latest update solved my issue, which I confirmed it did not. Neither of the two most recent updates has mentioned a fix for the timing problem; they only mention performance improvements for the TV. I believe the TV's responsiveness is the root cause of this issue.
About an hour later, I received another email from them confirming that my issue has been escalated to their product specialists.
Fingers crossed this gets fixed. It's a real shame for such high-end equipment.
Been having this issue with my 50X90S TV and HT-A3000 soundbar.
This issue has been going on since May. After I sent an angry email to Sony, I got a call from them last week. They told me the issue has been escalated to their top-tier tech team to identify the source of the problem. Today, I received another email stating they are still working on it.
The funny thing is, although the error shows up, everything works fine. It's just a cosmetic glitch.
I hope they find a solution to remove the error or at least change the message to something like, "TV is waiting for sound system, please wait."
If they offer a replacement, I probably won't accept it for two reasons:
I'd likely end up with a refurbished unit.
A different model might still run Android 12 and have the same bug.
For now, I'm just waiting for a proper response from Sony.
I’ve just received news from Sony regarding the problem. They’re promising a fix with the next software release. Here’s the email:
Dear Customer,
Thank you for your understanding. I confirm that the issue has been reported to our development department and is being actively monitored.
A fix is planned for an upcoming software update, although we cannot provide a specific release date at this time.
We appreciate your patience and remain available for any further questions or assistance you may need.
Kind regards,
Gisselle
SONY SUPPORT TEAM
Thank you for sharing this update.
My own case has also been escalated internally, and I am in contact with a dedicated manager regarding its status. I have received a weekly update email for the past seven weeks, and each one states that they are still awaiting feedback from the appropriate internal team before proceeding.
Hopefully, I will receive the same positive news that you have shortly.
Thanks again for the information.
Hi there,
Any one got the update?
If yes, was the issue really fixed?
Thanks
Unfortunately the newest update hasn’t fixed the issue. I’m so disappointed but not surprised at this point. I’m almost giving up. I can’t believe Sony has ruined the experience on a 3 year old TV with a software release. I paid $4000 for this TV. It should take this long to fix this.
