The normal freeview (not youview) tv guide when scrolling through the list and you select a channel it first opens a programme information screen where you get option to View, Records, set reminder etc
Would be nice if there was a way to disable this screen, old tv's used to go straight to the channel which to me was way better, less fuss
Thanks a lot for your suggestion - but this has been changed by purpose to make use of the additional options easier.
Well i thought as much but would be nice to have an option in the menu to turn off programme information for people that dont need it 🙂
