Hi all.
Since yesterday, my TV is in safe mode with volume 0 icon on bottom of screen, I can't switch safe mode off by restarting, soft reset, factory reset. I can increase volume for moment but it is going down it self to zero, remote control seems to be OK. I have no idea what I can do with it. Please help.
Please check this support article about safe mode:
https://www.sony.co.uk/electronics/support/articles/00127645
Yes I was trying this before, no success.
But solved the problem. Remote control from amazon fire stick was causing some conflict with TV after taking battery off i was able to reboot TV and and switch off safe mode.
Hey @AngryKriss,
Thanks for sharing this info!
It'd be helpful to others if you mark the thread as solved so they can go to the solution faster ^^
- JD
