I keep getting the “Wi-Fi not connected” message pop up on the screen!
The thing is, everything is working fine, prime, YouTube, Netflix etc
i have no idea why this has started happening but it’s kind of annoying.
Has anyone else come across this or know a fix?
Hard wire it and switch off WiFi!!
Not an option unfortunately, hence the post asking for help!
Have you got a dual band router? Maybe that's causing the problems. I honestly don't know. Maybe try resetting the WiFi on the TV, I mean set it up again.?
