Screen keeps flikering and wobbling when using ps4 pro and Sound Bar menu and 4k player is it the hdmi cables.
Hi it was the 2 hdmi's I had in. BUT thanks for you reply but just cheaked again now and the TV has fixed the issue all working fine now no issues very strange as I've been stressing for a hour. Don't under stand but all seems fine now. Thanks again for reaching out.
if it happens again I'll let you know. Thank you.
Sound keeps going off when using sound bar. Can't use ps4 pro screen wobble and Sound Bar menu green. Is it the hdmi cables. HELP PLEASE.
Hello @D-Law81,
does this only happen with one particular input or even on the TVs internal apps/menus?
- Nic
Hi D-Law81, maybe the USB cable is faulty, try to use different HDMI cable, also try different HDMI ports.
Hi @Piscie,
maybe you have overlooked it, yet the issue has already rectified itself, hence the post is already marked as "solved"
- Nic
