I have Sony TV KD55XD8559 which I am using for monitoring system.
How can i disable the Screensaver, in the setting the maximum is two hours and then it goes to screen saver.
i need it to be active 24/7.
thanx alot
Hi there,
I'm a little confused - are you looking the screensaver to be active at all times?
Best wishes,
Sean Mc
@Sean_Mc wrote:Hi there,
Best wishes,
Sean Mc
It seems quite clear to me that he wants, as he says, to disable the screensaver entirely.
@kfcatv, is the stuff at this link any good to you?
