My TV occasionally turns itself off immediately after it has been turned on. Sometimes you can switch it straight back on and other times it does a full reboot where you get the Android message. Has anyone else had this issue?
I don't think there are any updates to do.
Many thanks
Similar. After the last Sony update my TV started to randomly reset - sometimes when first turned on otherwise it can be anytime (and then is immediately followed by asking me if I want to join Rakunen TV! Hope the next update will resolve this.
Hey awhatnell, what's the model number of your TV and the software version?
