Hi there,
I purchased a KE-55A8 TV to use the Acoustic Surface as a Centre Speaker in my 5:1 setup - driven from my Denon x4100W. Foolishly I did not check to see if this Model had Centre Speaker connections - it doesn't.
Can anyone tell me if there is a way of connecting the TV to my Amp Centre Channel to be able to utilize the Acoustic Surface?
many thanks
Acoustic Surface Audio in this model is from "himself"...
You can only use an external Central Channel.
Ok - thanks.
I thought that would be the case...
Hi KingPuck,
I agree with Marino, you can only use an external central channel.
