Recently purchased this TV, have now decided I would like to try 3D. The only Sony glasses I've found are £50+ for one. *****!
Tried some Sumsung as suggested by a Sony rep at Curry's. They never worked SSG-5100GB. So can anyone recommend working glasses other than me spending over £150+ for 3 pairs of Sony's own.
Cheers Tinshed123
The model above should work. I use SAMSUNG SSG-P51002/XC and the difference is that these are 2 in a package for 30 Euro, so 15 Euro each.
You have to pair them to the TV, they are Bluetooth. Just consider that not all Side by Side and Over Under videos on youtube are recognized as 3D by the TV, but you can find a lot that work. Also Sony's factory Video player can play SBS videos, after you turn on 3D from the Action menu button.
